Hello everyone,
Actually, I think you can use the mouse to make the cursor be on each peak, but I understand how the behavior is at first a bit misleading. I am guessing by the descriptions I read that everyone is moving the cursor horizontally, and watching it "bounce" around the plot it is snapped to. Indeed, using this technique I cannot get the cursor to jump to all the peaks. However, what you can confirm is that for each vertical line of pixes in "dense" plots, there can be more than one data point represented. In the example CC posted, this is indeed the case. However, you can navigate to a peak by grabbing the cursor at the actual "point" it is currently snapped to (ie. at the intersection of the horizontal and vertical lines defining the cursor), and move it vertically. For reference, let's call that point on the cursor the SPECIAL point. You should then see that the cursor jumps between points that are defined for the plot, but due to compression, are represented within the same vertical line of pixels. In fact you can drag that point all over the plot to snap to arbitrary points. I have attached a screenshot and a trivially modified version of catch_peak 2.vi which I used to play with this.
I think what LabVIEW does, and in all fairness must do, is for a particular pixel relative to the horizontal, pick one of the plot's values which is represented in the corresponding vertical "line" of pixels. Then, if you want to jump/snap to other points which are represented in that vertical line, you will have to click and hold carefully on the "cursor point" and move it up or down - since it is still snapped to the plot.
If I have missed something subtle in the discussion, don't be shy, and I'll explore this more and take it to R&D if necessary! Otherwise, I think this behavior is at least reasonable 🙂
Best Regards,
JLS
Message Edited by JLS on 03-30-2006 04:53 PM
