06-26-2009 11:52 AM - edited 06-26-2009 11:53 AM
Dear all,
I'd like to know whether there is any way that I can recognize which frame is running in the flat sequence ?
If I have five frames in the flat sequence, I want to keep track of each frame in the front panel visually. I'm using LV8.2
Thank you for your reply in advance.
Yoon
06-26-2009 12:05 PM
06-26-2009 12:10 PM
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
06-26-2009 12:16 PM
Thank you very much for your replys. It helps a lot.
Yoon
