06-16-2009 04:59 PM
06-17-2009 02:25 AM
Hi Mike,
you can use an event structure. There you can use the event "Key down?" and check if the scan code is 15. If this is the case, then you can reject it and set the focus to the object you want, read this information from your own array, which you build as you need it.
Mike
06-17-2009 08:03 AM
I don't think I was clear enough. I don't actually care about the order that the tabs go through. My goal is to reorder how local variables appear in the list when you are selecting an entry for the variable. In 8.2 the order of the list is directly related to the tabbing order. So I would have to actually edit the tabbing order directly to have the effect I want. Again any help is appreciated and thanks for the suggestions Mike.
Mike
06-17-2009 09:33 AM
Off-hand I don't think you can do this, even with scripting, as I just took a look through the available properties and methods.
However, this leads to a different question: why? Indeed, the fact that you want to do this leads me to believe that you may be using way too many local variables, as this is not normally an issue with normal LabVIEW programming. We usually see this sort of thing when folks lean a wee bit too much on the "local variable crutch".
