> Is there any one knows how to use labview 6.0 to make a "continue"
> function like the one in C language?
> I am using labview 6.0 and i like to know is there any one knows how
> to stop the current iteration in while loop or for loop and continue
> to do the next iteration,just like the "continue" statement in C or
> C++ language?
Make the code that you may want to skip conditional. Compute the
condition, wire it to a case structure, and place the code in the case.
If you don't want to see this, put the case and inner code into a
subVI and give the operation a good name.
Continue is a control flow statement alot like a goto. It isn't
necessary and causes bad things to happen to the dataflow in your program.
Greg McKaskle
