Is there an easy way to convert a long string into an array?
I can convert a long string into a 1-d array by parsing and using build array, but I would like to know if there is a function to make this easier.
For example:
from/   aaaaaaaabbbbbbbbccccccccdddddddd         (string of ascii)
to/       an array that is 1-d with each element having eight characters
          aaaaaaaa
          bbbbbbbb
          cccccccc
          dddddddd
Thank you.
(2,355 Views)
Accepted by topic author chuck72352
Try something like this:
(If you can guarantee that the string length is an integer multiple of 8, you an drop the two triangular modes in the upper left. ;))
Message Edited by altenbach on 03-14-2010 06:40 PM
(2,344 Views)
Works great! Thank you.
(2,329 Views)
