Is there a way to *visually encrypt* a field in the Prompt User for Input vi?
Hi, I am using the Prompt User for Input vi as a login window; two fields - username and password. Is there a way to *visually encrypt* the password field so like stars or something come up when you type in the password but the contents are still alphanumeric when you pass the value down the line?
Thanx!!
(2,702 Views)
Sure. Right click on the Express VI and select Open Front Panel. This converts the Express VI to a normal VI. Right click on the string control and select Password Display. Save the modified VI.
(2,696 Views)
Sweet! Thanx a bunch...
(2,691 Views)
