02-12-2020 07:35 PM
I am new to LabVIEW and have a question. Is there a way to completely skip the GUI altogether and just drive a LabVIEW program with a "settings" file/spreadsheet that initializes variables and such?
Thanks in advance!
02-12-2020 10:10 PM
Of course. Search the forum or LabVIEW example finder for how to read either a text file or an Excel file.
Then you can use that data in your program.
02-13-2020 07:27 AM
Did you notice the File I/O Palette on the Block Diagram? In addition to text, "Delimited Spreadsheet" (.csv Text files), and otherwise-unformatted Text files, you can also find (on this Palette) functions to read/write XML files and Configuration (a.k.a. ".ini") files. Finally, if you have the Report Generation Toolkit installed, you can read/write Excel (meaning .xlsx) files, but this shows up on a different ("Report Generation") Palette.
02-13-2020 09:04 AM
You can also use JSON files if you are familiar with those. check out "JKI JSON" or "JSONText" on the VI Package Manager.
02-13-2020 09:20 AM - edited 02-13-2020 09:20 AM
There is also a full set of database connectivity tools
So to recap...
1) ini file
2) xml
3) json
4) csv
5) xls
6) database
Shall I go on?
02-13-2020 07:36 PM
Got it! Thanks everyone for the replies!
