Is there a way to use a DAQ VI without DAQ hardware?
Is there a way to use a DAQ VI without having DAQ hardware?
Steve
(2,751 Views)
Steve,
Yes, you can use the DAQ VIs without the hardware. With the DAQmx 7.5 and 7.4 version of the driver, you can simulate DAQmx devices. This will save you some time, as you can program and test your application without the actual HW present. However, you will not have the full functionality with simulated devices.
Somendra
(2,747 Views)
Yes, it seems to be working without the Hardware.
Stephen
(2,741 Views)
