04-04-2008 09:17 AM
04-07-2008 02:52 PM - edited 04-07-2008 02:55 PM
Splitufan,
Welcome to the NI forums! The NI-SCOPE driver will allow you to configure your trigger for a RTSI line on the NI 5122. This is great news because all you have to do now is configure the actual RTSI cable and export your trigger from your NI 6224.
1. To configure your connected RTSI cable, open up Measurement and Automation Explorer (MAX).
2. Expand Devices and Interfaces
3. Right click NI-DAQmx Devices and go to Create New NI-DAQmx Device > RTSI Cable
4. Now that the RTSI cable is created go ahead and Right click the newly created RTSI cable and add both of your devices (6224 and 5122).
In LabVIEW you will use the DAQmx Connect Terminals.vi to route the signal from a trigger line (PFI0…) to RTSI 0.
When configuring your trigger for the 5122 you will specify the trigger source as RTSI 0.
I hope this helps!
04-10-2008 04:45 PM
