You can drive IE with Lv through ActiveX: When you have creating an IE
ActiveX reference with Lv, you will be able to open your file and then print
them programmatically...
"PH!L" a écrit dans le message news:
50650000000800000074560000-1027480788000@exchange.ni.com...
> I created a Html-Report wich includes a jpg-Picture.
> Actually there is no way, in the Report Generation, to Print a Html
> file. I Would be
> glad if you have a solution (sub-vi?) to Print a Html file directly in
> Labview.
> Thanks
> PH!L
