Is there a way to have an image (simple circle) change color in respect to values in an array?
I have a vi that processes data from 5 different sensors on a sole. I have graphs of the data but for user-friendlyness I would like to have an image that relates sensor placement to data.
In an ideal world I have 5 cicles on an image that change color depending on a certain row of the data, with a scroll bar that goes through all the rows.
Sort of like a boolean led circle but with more than just T/F
Is this possible?
Thanks!
(2,860 Views)
If you can accept a square instead of a circle, you can use a color box indicator.  It's just like a numeric indicator (it's in the numeric palette) but it displays a color instead of a number.
(2,848 Views)
The Silver palatte has a round color box.
If you don't have 2011 or 2012- a search on the forums will yield a custom color box that is round.  (check my posts circa fall 2009) Here
"Should be" isn't "Is" -Jay
(2,838 Views)
Customizing square color box to round and dimming, it's crazy coool!..credit goes to altenbach
(2,827 Views)
@apok wrote:
Customizing square color box to round and dimming, it's crazy coool!..credit goes to @altenbach
It's even an Idea. 😄
(2,811 Views)
