Is there a way to get data from a Vernier Magnetic Sensor into a data table in LabView?
I'm trying to get the data from the sensor into a table so that I can read the points from that instead of trying to read the data points from a chart. The chart shows data being collected, but I'm having problems reading the chart with a good amount of accuracy.
(2,600 Views)
If the data is going to a chart (as opposed to a graph), you can use the chart history property node to get an array of data.  Then you can display that array.
Lynn
(2,598 Views)
It works great, thanks.
(2,595 Views)
