Is there a way to change graph's annotations default color?
I would like to change the default yellow color of graph annotations at development.
I created code to list and change the color of annotations but this also negates color changes made by the user. The yellow used is only visible on dark graph backgrounds. I use white graph background for better printing.
(2,344 Views)
It's a little clunky, but you can create a graph as a custom control, edit all the properties the way you would like, and then add it to your palette view.  Every time you need a graph then, you pull your custom graph rather than the stock graph that ships with LV.
I suppose if you're feeling enterprising you could try to track down the original control in the LV system files and replace it with the style you like as well.
Hrm, 1:30am post... you might just take this with a grain of salt too! 🙂
Joe Z.
(2,337 Views)
Thanks Joe. That is some what of the long way around but it's worth it in this instance.
(2,314 Views)
