Is there a way that the I can control the Labview Program of two devices remotely using some kind small size computer?
Hi guys,
I have a problem with what kind of device I need to use to remote access the LabVIEW program.
There is a LabVIEW program that I developed for two devices, one is a pluser-receiver (for Ultrasonic sensor signal detection and analysis), and another one is Arduino Mega 2560 (for controlling the sensor using SPI). The LabVIEW program is developed using my Laptop with two USB cables connected. The question is that these two devices (pluser-receiver and Arduino) will be sent to a field for testing, and have minimum space for a Laptop to connect them and access the program.
So, is there a way that the I can control the Labview Program of these devices remotely using some kind small size computer(Raspberry PI maybe)?
My inintial thought is to download LabVIEW software on Raspberry Pi (using Ubuntu OS) and connect the pi to these two devices using USB cable and install 4G/LTE hat on the pi and remote access to the pi and access the Labview program, but I am not sure if there going to work.
Any advice will help, thanks in advance!
Edward Li
(1,161 Views)
Hi Edward,
you may use a LAN-2-USB bridge to extend the distance between your laptop and your two devices…
(1,131 Views)
