02-21-2008 09:56 AM
02-21-2008 10:16 AM
02-21-2008 10:23 AM
02-21-2008 10:27 AM
02-21-2008 10:46 AM
Hi Dave,
In JB's code, change the event handled by the second case to 'Mouse Up' event and it seems to do exactly what you want to do.
Vikas
02-21-2008 11:44 AM
I'm still working through making something like JB's VI work inside mine. I don't fully understand yet. It's not as intuitive to me as I'd like it but I'll get it.
I don't understand changing the 2nd case to "mouse up". Thanks everyone.
02-22-2008 02:27 AM
02-22-2008 06:39 AM
It is a throttle that I intend to control with a Step Motor that receives ASCII commands.
Let's say I'm at 20% of full throttle and I want to go to 50%. The user clicks on the slider and moves it up to 50 changing the value that will be sent to the throttle control. When the user releases the slider I'd like it to then send the new value to the motor. They wouldn't get instant change but it would be a little better than having to push execute after changing the value.
I hope that helps.
02-22-2008 07:16 AM
02-22-2008 10:35 AM
This might still need to be tweaked a bit. (The entire thing could be made into an Xcontrol).
