Is there a cable like the SH68-68R1-EP with a VHDC instead of the standard SCSI?
I have an application where I need a VHDCI to SCSI cable but I need the SCSI side to be terminated with one of the low profile right angle style connectors like that found on the SH68-68R1-EP offered by NI. Does anyone know if there is a place to get said cable?
(2,247 Views)
I've found L-Com (http://www.l-com.com/home.aspx) to be a good source for cables.  The do have a number of SCSI cables, but I don't think they have any standard products in the same connector configurations as the NI DAQ/DIO/etc. cables.  If you need more than a few, they may be able to make something custom for you.
Also, NI claims the internal shielding, pairing, etc. of their cables are designed for the application.  I don't know if that is important for your cable.
Mark Moss
(2,245 Views)
That website does have some good cables on it, but unfortunately not what I need. I may just have to buy the SH68-68R1-EP and use a SCSI to VHDCI Adapter. Not an ideal solution, but it would work
(2,242 Views)
