09-17-2007 04:22 PM
09-18-2007 11:46 PM
I believe you are referring to CAR 41K7AIKQ entitled "eval function needs to be blocked from the run-time engine" linked in the LabVIEW 8.5 bug fixes document.
The root of this CAR is that the eval function is not supported in the runtime engine, yet this wasn't documented in LabVIEW 8.2. The net result is that in the 8.2 help for eval, there's no mention that it is actually unsupported in the runtime, but in the 8.5 help, there is. This and you would receive a more descriptive error saying "'Function not available (RTE)" instead of the generic -90001 which is "A problem occurred in a subVI call".
Craig D
