Is the (stock) content the same across the online/self-paced, online/instructor-led, and classroom/instructor-led courses?
Apologies if this isn't the most appropriate forum.
My question is primarily about the LabVIEW Core 1 - Core 3 and TestStand 1 classes.
Is the stock content the same in the 3 aforementioned formats?  By stock I mean "excluding any additional material presented in response to a question asked by a student".
Thanks.
(3,825 Views)
blawry,
I am not excatly sure what you are referring to when you ask if the Content is the same between the formats. The content of Core 1 will be different Core 2 which will be different from Core 3. Could you clarify what you are asking?
Reagrds,
Ryan
Ryan P.
CLA
(3,753 Views)
Accepted by topic author blawry
The content should be identical.
The only exceptions I have seen is with certain demonstrations or exercises which can't be done without physical access to the system.
For example in the online Real-Time class you can't personally connect the hardware to the temperature chamber, so instead you can see the hardware already set up and interact with it.
Instructors often also add some of their personal experience to the classes and may explain differerent sections differently.
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(3,745 Views)
Ryan, Sorry for not being clear. I meant: for a given course--such as LabVIEW Core 1--is the content (perhaps I should have said syllabus) the same regardless of the format, whether online/self-paced VS online/instructor VS classroom? Say I was to do LabVIEW Core 1 online/self-paced, would I then be adequately prepared to take LabVIEW Core 2 in a classroom, or would I be missing topics that were covered in LabVIEW Core 1 classroom? (I'm trying to maximize my training dollars.) Thanks. Brian
(3,736 Views)
Craig, That's what I was hoping. Thanks. Brian
(3,735 Views)
