03-01-2011 10:44 AM
Hi my name is DIego and I was wondering if anybody here knows if the NEXYS 2 board (with spartan 3e FPGA) from DIGILENT is compatible
with the LABVIEW FPGA module.
Digilent is also the Manufacturer of the SPARTAN 3e STARTER BOARD
03-03-2011 11:45 AM
Diego:
The NEXYS 2 is not officially supported, but if you'd like to try it, you can attempt to follow the guide for the Spartan 3E here (substituting your NEXYS 2 for the Spartan 3E).
Again, the NEXYS 2 isn't officially supported, so if it doesn't work like the Spartan 3E starter kit board, then you won't be able to use LabVIEW FPGA with it.
Good luck!
06-30-2011 02:36 AM
Hi Diego, Did you ever get the board working with Labview I was going to try the same thing and just wanted to see if I would be wasting my time?
06-30-2011 01:04 PM
Sorry dude but it´s imposible to get the nexys 2 working with LabView
07-01-2011 02:52 AM
Thanks for the reply. You have saved me a lot of time!
07-01-2011 08:31 AM
Can you share how you are using the Nexys2? Is this for a senior design project?
07-02-2011 08:36 PM
I m using this board for a coursework project, I m triyng to run Linux on it
some one know if is this possible ???
07-05-2011 04:12 PM
I would recommend some of the IRC channels/mailing lists dealing with uCLinux (Google is your friend)
Otherwise, as good a place to start as any would be here (result of a quick search)
09-24-2011 09:06 AM
10-03-2011 11:10 AM
Frenky 已写:
Check this link:
great! But how do I build the nexys2 support files?
