thout errors) very well one program written and compiled on Linux with gcc command for C program into Labview ? I know Labview support C codes, but I don't know if support some program done on another operating system, like Linux with other compiler (gcc).Hopefully, the differences in the implementations of the language itself would be fairly well documented. Therefore I would suspect that the biggest problem you'll have in this port is when the code starts trying to connect to the outside world--like the serial ports you mentioned.
Personally, if I had documented C code (or at least a reasonable description of what the code is supposed to do) I would say to heck with CINs and just port the application to LV. You probibly won't spend any more time doing a complete port and the result will be more extensible and maintainable that the C ever was (or could ever be). But that's just me and my aversion to doing things the hard way...
Mike...
