01-08-2019 10:01 AM
ok i'm going to try and explain what i'm interested in doing. Forgive me if i fail.
I am generating intensity chart data from a measurement system, the target size changes however but the FOV of the sensor remains constant. So there are target data that fill the chart window and there are targets that fill a small percentage of the chart window. Usually what we have to do is post process the data to custom trim it, cutting out the garbage outside of the target.
Is it possible to do this visually on the chart? I'm envisioning (2) vertical lines and (2) horizontal lines that can be manually moved on the chart, once the locations are set the data contained withing the manually formed box can be saved.
I've experimented with entering row and column numbers to delete data from the display which will work but having a visual method would be much better and faster (less iterations).
01-08-2019 11:14 AM - edited 01-08-2019 11:16 AM
In the subject line you are mentioning "chart" and "graph". Big difference! Which one is it?
(You can always use mouse-down events and get the coordinates, even draw visual feedback using the plot-images overlay.)
Can you attach some typical code and data?
01-08-2019 01:35 PM - edited 01-08-2019 01:40 PM
Have you looked at cursors? Vertical, horizontal lines, associated events, coordinates.
Intensity chart does not have them, but Intensity graph does. Right click -> Properties -> Cursors tab.
PS. Also changing axis limits, for example with tools in Graph palette might be enough - Save everything, that is shown. Works for both - chart and graph.
01-08-2019 01:36 PM
Hi coolhand,
As soon as you replace the "chart" with a "graph" you can use cursors to do exactly what you describe in this sentence…
