Is it possible to restart the embedded NI webserver from an RTEXE without restarting the RTEXE itself?
I'm having this problem with HTTP requests to a webservice timing out after X amount of up-time.
The webservice is running on a cRIO running NI Linux RT.  It is included as part of the RTEXE build.
I can monitor when my issue occurs, but is there a way to restart the webserver from the associated RTEXE link a set of Linux command line calls or similar or is restarting the RTEXE the only way to do this?
I saw my father do some work on a car once as a kid and I asked him "How did you know how to do that?" He responded "I didn't, I had to figure it out."
Message 1 of 1
(2,073 Views)
