Is it possible to programmatically change the font of all of the parent categories in a tree control without changing the children?
I am changing the tree programmatically to relay the results of a search, and I would like to change the font of JUST the parents to bold (or possibly changing the font size as well).  Is it possible to do this without running through a for-loop and actively selecting each parent and then applying the font changes?  For instance, I would like to go from the first figure to the second.
Thanks.
(3,388 Views)
Hi edweir,
why is running through a for loop a problem? If you defer panel updates, then it looks like a jump from your first image to the second.
Mike
(3,374 Views)
hmm...
Mostly I was just worried about the case when I have a huge amount of entries and watching the panel slowly change... However, deferring the front panel update might be a solution.  I'll check that out.
Re: the original question, it is not possible then to change properties for all elements at once i.e. all the parents or all the children?
Erik
(3,358 Views)
Returning to the step before I thought that I was at... how do I select the active cell for the tree control.  I tried to set the ActiveItem Tag property, but it only sets the active item and does not set the ActiveCell (at least I think so..), because the property that I try to set in ActiveCell does not properly change...
Suggestions on how to select the ActiveCell programmatically?
(3,352 Views)
