Eugene,
I'm not entirely sure what you are trying to accomplish based on your description above, but I do have a few suggestions for you nonetheless. If you are using LabVIEW 6.1 you can use the new Events structure to monitor front panel objects for events like mouse clicks. You can view some of the events examples that ship with 6.1 for more information.
If you are not using 6.1, however, I recommend you take a look at the "Mouse Control Demo" example that ships with LabVIEW 6i. With this example, a trick is used where you can monitor mouse events on a picture control. Basically, a chart is covered with a picture control, and whenever the user moves their mouse over the chart or clicks their mouse on the chart, those mouse events are read via the picture
control on top of it. That description should clear up somewhat when you look at the example.
I hope one of these suggestions gets you started in the right direction. Good luck, and have a pleasant day.
Sincerely,
Darren N.
