Is it possible to load a picture into another picture
I need to put a  symbol(save as picture A) into another picture(shown on front panel).Is it possible?which  subvi can I use?
Thank you
(2,671 Views)
If you actually want to load the pictures from the files while the program is running, you can use the picture VIs (found in the Graphics & Sound palette). They let you load a picture from a file, place it into a container and play around with it. You can easily load 2 pictures and overlay them
but you will have to know how to this properly. There are probably some examples in the example finder.
___________________
Try to take over the world!
(2,665 Views)
Thank you ,I've got it
(2,651 Views)
Thank you .I've got it
(2,651 Views)
