Reply
Is it possible to establish an I2C communication using PCIe-6363?
Is it possible to establish an I2C communication using PCIe-6363? If yes any example would be appreciated.
All I2C labview solution are using LabVIEW FPGA modules but PCIe-6363 doesn't seem to be compatible with FPGA modules.
However PCIe-6363 can generate dgitial input/output signal up to 1MS/S which is more than enought for 100KHz I2C communcation.
Charles
(572 Views)
Re: Is it possible to establish an I2C communication using PCIe-6363?
(564 Views)
Thanks for your link,
it clearly explains that a Per-Cycle Tristating DAQ is necessary so I can't use the PCIe-6363 for I2C communication.
(540 Views)
