Is it possible to embed one LV program to another one?
I have two independent LabVIEW programs and each one has its own interface. I want to add a button in one program and when I click it, the other program interface pop out. Is this possible?
It looks like a sub-vi, but sub-vi can't pop out an interface.
Thanks.
(2,808 Views)
You can set a subVI to open its front panel when called (File>>VI properties>>Window Appearance). You can also open its FP using the FP.Open property.
You can also use a subpanel (containers palette).
___________________
Try to take over the world!
(2,798 Views)
Hi ThunderBird,
'tst' is right about the different options of launching a VI/SubVI. In addition to his suggestions, I want you to check out this small example I once made:
Launching Other VI and Closing Itself
Is this what you're looking for?
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,776 Views)
Hi, Philip
Your program is a beauty, it answered two of my questions. Thank you.
(2,768 Views)
Thanks ThunderBird,
I spend over an hour creating the icons...
I'm glad that you could use it.
Thinkbot Solutions
(2,748 Views)
