05-30-2018 07:46 PM
I have built a case structure and I use the boolean output to control itself. Is it possible?
05-30-2018 08:17 PM
What is a "boolean output" and what puts it out? What is "itself" (case structure? output?) If you are talking about an output of the case structure to be used as selector in the next iteration, use a feedback node or shift register.
It would really help to attach your code, then explain in detail what you are trying to do. What is the purpose of all this?
There might be a better overall solution than just trying to force connect things in a certain misguided way that is against the rules of dataflow.
05-31-2018 12:21 PM
Thank you, problem solved.
05-31-2018 02:24 PM - edited 05-31-2018 02:25 PM
I see you have figured it out, but you still might want to show us what you did because your question sounds like the foundations of a Rube Goldberg Machine.
06-02-2018 04:29 PM
It's like the pictures and VIs that I attached. No errors only when I add a while loop.
06-02-2018 10:22 PM - edited 06-04-2018 10:38 AM
Any toplevel program needs a while loop. (The "run continuous" button is not for running, but for debugging. A program without a while loop is not interactive and just rolls down the hill once with the current values. Not very useful).
You don't really need to anchor the init terminal on the loop, you could just globally initialize the feedback node (and the VI would not be broken, even without the while loop)
Even if the run arrow is not broken does not mean that the program is logically correct. Even a blank VI is not broken but is arguably not very useful.
You still have not told us what problem you are trying to solve. Somehow I guess you are looking in the wrong place.
Your code makes very little logical sense.
06-03-2018 02:19 AM
Jason, these questions you ask are really basic, and even if this forum can give help you here, your learning curve could be much better with a different learning approach. I recommend you to take some of the tutorials, or much better, if you have access to the LabVIEW Core 1 "self-paced" training. Depending on your licence, you might access these training videos from NI.
You can find several links under section "Looking For Free Training":
https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495
06-04-2018 09:18 AM
Okay, I see what you did there. Now I have to ask why do you need to do that?
