Is it possible to compile FPGA vi without target?
Hello everyone,
I just want to ask if itis  possible to compile/run  a FPGA vi with no target device? does it exist a simulator to replace the real target and see how the device will behave?
Thanks in advance.
regards,
ND_CV
Message 1 of 8
(3,092 Views)
Hi CV,
To be able to compile the FPGA VI you need to set a certain target in your project.
(But you don't need that target connected to your computer.)
Later on you can run the FPGA VI in simulation mode without hardware attached, with some limitations (regarding timing and certain FPGA features).
Message 2 of 8
(3,069 Views)
Hello GerdW,
Thanks for the fastest reply,
is there any manual / tutorial for doing that (simulating FPGA target even if it's not connected) ?
best regards
ND_CV
Message 3 of 8
(3,066 Views)
Accepted by topic author CV_ND
Hi CV,
Open the FPGA VI, look at the lower left corner of the window.
There is a selection box where you can switch the execution system from "FPGA" to "Simulation"!
Edit: NI recommends to run in simulation mode before compiling…
Message 4 of 8
(3,040 Views)
Hi GerdW,
I'm not able to find the selection box that you mentioned.
can you please help me finding it?
CV-ND
Message 5 of 8
(3,004 Views)
Hi CV,
I don't see any FPGA code in your image!?
Message 6 of 8
(2,930 Views)
If you are using DAQmx on a cRIO, you are not using the FPGA in a user-configurable way.  The code you have is on the RT side of the cRIO.
Message 7 of 8
(2,924 Views)
Hello everyone,
thank you very much for your answers.
I have found how to simulate the FPGA vi, but how can I do that for an RT vi?
Message 8 of 8
(2,908 Views)
