Is it possible to Pass Command line arguments to a LabVIEW DLL
Hi all,
I have requirement  where, I have to call a labview dll from command line and pass argument s to the  the dll.
I want to whehter  it is possible to call a labview dll  from command line and pass  arguments through command line.
Please share your views on this
Regards
Aju Samuel
(4,268 Views)
How are you calling the LabVIEW DLL from the command line? A DLL is just a library of code so it can't be called directly (unless there's something I'm missing? I thought you could only run executables from the command line?
It is possible to pass command line arguments to a LabVIEW Executable by ticking the 'pass all command line arguments to application' option in the build specification and you can then access them using the Application property Command Line Arguments which returns an array of arguments - there's some information on that here: https://decibel.ni.com/content/docs/DOC-10281
(blog)
(4,259 Views)
Hi Sam,
Thanks  for the reply
I tried  calling Labview excutable from command line  and passing argument s through command line. It was succesful.
But  I have requirement where I have  ot call  labview dlls from  a third party software  which only supports  command line scripting.
I want  to make sure  whether it is  possible  to  call  LabviewDLL from command line . Other  wise  i have  go with the executables
Regards
Aju Samuel
(4,253 Views)
No, it is not possible. As I said, a DLL is a compiled library of functions - it cannot execute on it's own. You can call the functions in that DLL from any programming language by using the appropriate include/function calls (from the header file that gives you the function prototypes). This isn't just true for LabVIEW - it's the same for any other DLL.
You will need to either call the functions from the DLL in your other software, or write a LabVIEW executable which takes in the command-line arguments and runs the appropriate functions. This executable could even call the LabVIEW DLL you have produced!
(blog)
(4,246 Views)
