07-19-2009 12:41 PM
07-19-2009 01:09 PM - edited 07-19-2009 01:11 PM
The button resets once it is read by the code. This means that the terminal should be inside the event structure. If you place the terminal outside, it will only get read at the beginning of the run and then never again and it will not reset.
If the terminal is indet the event structure, it gets read by the code (even if it is not connected to anything) and will this reset as soon as the event has a chance to execute.
