04-22-2013 07:53 AM
I have an FPGA project file which I use to define FPGA memory blocks, I/O etc. We have a company project that pulls together various common VIs that people have written. I included the folder with my project into this top level project as an auto populating folder. It seems to work having a project inside a project but I am not sure if it is good practice.
Any thoughts?
Andy
Solved! Go to Solution.
04-23-2013 01:15 PM
Hi Andy,
i don't see a problem with that as long as you are keeping track of this and don't put too many unecessary files in there or it will get cluttered
04-24-2013 01:11 PM
I always create a separate project for FPGA files. Then I include that project inside the main project that calls the FPGA code. A project inside a project. Works well and is well organized. Once I even had two separate FPGA projects inside the main project. This works also.
04-25-2013 08:21 AM
Thank you both for the replies.
Andy
