04-24-2013 03:17 AM
In my LabVIEW program needs to be an action when the item of a text ring changes. Namely there has to be a reset of a value when someone changes the item of the text ring. Can I use a property node for that?
Thanks for helping!!
Greets
Pieter
04-24-2013 03:19 AM
Do you know the event structure?
04-24-2013 03:25 AM
I never used it before, can you give me an exemple?
Thanks!
04-24-2013 03:52 AM
I found an exemple but is doesn't work.
04-24-2013 08:25 AM
I solved my problem with a shift register and a case structure. I compare the new value of with the old one. When these are different, the case structure resets a value.
04-25-2013 02:20 AM
Hello Pieter,
As Henrik already said, it sounds like the Event structure is a better option here.
Maybe you can share the example you tried to see if we can help you?
