Is cRIO-9073 compatible with LabVIEW 8.5.1?
I just received a cRIO-9073 and a cRIO-9074.
When I configure them, both of them appear properly in MAX.
When I add them to a LabVIEW project, the cRIO-9073 does not show its FPGA target. The cRIO-9074 does show it.
I am using LabVIEW 8.5.1, is it compatible with the cRIO-9073?
Thanks for any help.
Michel
(2,842 Views)
Accepted by Michel_L
Hi Michel!
According to the following link, the FPGA and Scan interface of the cRIO 9073 are only supported in LV 8.6 using the driver NI-RIO 3.0.
The link where you can check compatibility is:
ftp://ftp.ni.com/pub/devzone/tut/crio_software_versions.htm
Have a nice day!
Oswald Branford
(2,841 Views)
Hi Oswald,
Thank you very much for the very prompt response. This should solve my problem.
Also, after I read you message, I finally found the link to the software revision/compatibility file in the CompactRIO cRIO-9072/3/4 Operating Instructions and Specifications on page 3:
 "Notes Visit ni.com/info and enter the info code rdsoftwareversion to determine
which software you need to use the cRIO-9072/3/4."
Thanks again for your help
Michel Lanthier
(2,818 Views)
