03-05-2022 06:00 AM
Hello, I generated a wsv file with systemvue, I need to load and call this file in labview, but labview does not support this type of file, how can I do to achieve my idea? Thank you very much!
03-05-2022 10:41 AM
WSV seems to be a proprietary file of Keysight. If you know the structure of data stored in the file, the forum members might be able to guide you to parse it.
Could you please explain why you would want to parse that Keysight proprietary workspace file in LabVIEW and what do you intend to do with it LabVIEW?
03-07-2022 01:03 AM - edited 03-07-2022 01:26 AM
Hello, I have built a radar system with systemVue. After exporting the modules of this system, I need to import this radar system into labview for use, so I need labview to call this WSV file.I found that if I open a wsv file in Notepad, the Code language is XML. Can I call him in the same way that I call an XML file.
03-07-2022 01:23 AM
Hi Wen,
Technically you can "import" that file using the ReadBinaryFile function…
Again: what do you want to do with this "radar system" in LabVIEW?
To repeat the other message: when you want to know about the data format in this WSV file then you need to read the SystemVUE manual or ask Keysight about their software!
03-07-2022 05:55 AM
Hello, I open this file with notepad, and it shows XML format, so I should call XML file or use the method you said is correct. Thank you very much!
