Invalid Mapping with SIT for an outport inside a subsystem in a the simulink model.
Hello everybody,
I am trying to use SIT to target simulink models on a PXI target. The simulink model contains a subsystem with an outport. I have created a mapping between the signal coming out of that outport to a waveform chart on the host VI. The mapping works fine when I run the model on the local host but becomes invalid when I target the dll to a pxi target.
I have been able to create a very simple simulink model and host VI that is mimicking this problem. This model does not do anything useful and is made to only demonstrate just this problem. I am attaching the model and the userinterface here.
Note: I have already taken care of the fact that I can not use signal storate reuse, block reduction and also cant use linked or linked+masked subsystems. A testimony to this is the fact that I am able to create mapping with other signals in the subsystem. Also outport is a virtual block in simulink so I have created a testpoint on the signal going into the outport to be able to probe it.
Any kind of suggestions would be appreciated.
Thanks and Regards,
Vicku.
(2,874 Views)
You have two options to be able to probe this signal in the subsystem that should work fine for this small example you posted. Let me know if they also apply to your actual model.
  1. You have the outport itself set as a test point currently in your subsystem block. Try setting the wire coming out of the subsystem outport as a test point and then rebuilding your dll. That should make the outport signal probable.
  2. Instead of probing the actual outport, you could probe the signal in the subsystem that is wired into the outport. In the case of your example that would be using_subsystem/Subsystem/Sum1:1.
Hope this helps!
Message Edited by Jarrod S. on 08-23-2007 10:59 AM
Jarrod S.
(2,870 Views)
Thank you very much for the reply. The problem got solved due to the first point in your reply. So far in my applications I was already using the point 2 that you mentioned. But a lot of times the mapping table become lot more readable if I am using the actual outport which has a proper name instead of some other function block inside simulink model. And yes now I understand that it should not work when I am making the signal going into the outport a test point as I was doing.
It was a great help.
Thanks again,
Vicku.
(2,862 Views)
