Interpolation on XY Graph with interrupts + Order of Plots
Hi All,
is it possible to having breaks on the interpolated XY graph? To display the results I have to enable the interpolation but I do not want to display the points( point style is none). Unfortunately if there is an interrupt between the X values the XY graph draws an unwanted line. In other word if the delta between X values are not 1 the interpolator should be off.
Secondly can I determine which plot on A XY Graph be on front? Is always the Plot0 on front and hides other plots (Plot1...)?
Please see attachment.
Regards
Tomi
(2,501 Views)
Sorry the attachment comes now.
(2,499 Views)
