Interpolating 1D XY data not working properly in my sample VI
Hi Friends,
I need to interpolate XY data acquired from a data acquisition device, the interpolate 1D VI  just takes the nearest value instead of interpolating it, see the attached code.
The 1D XY data is produced using a square of iteration (Y) and the time (t) at which the Y is obtained. The time interval is 0.2s for data generation and a 50 ms is added for the XY data interpolation. So, the raw data is
(t1, Y1), (t2, Y2), .... (tn, Yn), where Y = i*i, i is the iteration.
The interpolated data should be
(t1+0.05, Y1'), (t2+0.05), Y2'), .... (tn+0.05, Yn'),
Currently, Yi' = Yi, which is not what I expected.
Could someone help with this issue?
Gu
Message 1 of 13
(266 Views)
Read the help for "interpolate array". Your code makes very little sense.
LabVIEW Champion. It all comes together in GCentral GCentral
Message 2 of 13
(255 Views)
Accepted by topic author edmonton
Try this....
Message 3 of 13
(241 Views)
Message 4 of 13
(240 Views)
Using the 2D Interpolation makes this all much easier.
—Ben
Prevent your computer from sleeping programmatically!
Use Power Requests
Download from GitHub
Message 5 of 13
(230 Views)
How is that 2-D interpolation?
The VI is called "Interpolate 1D.vi".
Message 6 of 13
(226 Views)
Your VI is using "interpolate 1D" though. Smiley Wink
(also, if you look inside, it is using a scary amount of code to do the same, so it is only simpler on the surface Smiley Surprised)
Message 7 of 13
(224 Views)
Hi  Dr Altenbach,
Thanks a lots.
Gu
Message 8 of 13
(199 Views)
Hi Ben,
Thank you for your response. My LV is 2015 can not open the vi, Could I trouble you to save your VI to 2014 or 2015 version and upload it again?
Gu
Message 9 of 13
(195 Views)
@edmonton wrote:
My LV is 2005 can not open the vi,
Actually, you have LabVIEW 2015. (There is no LabVIEW 2005)
Message 10 of 13
(182 Views)
