Interfacing Omega PX309-500G5V with NI USB-6001
Currently having quite a bit of confusion working with an Omega pressure sensor. The Spec sheet for it is attached. I believe my wiring is set up correctly, but I keep getting output voltages of 4-10mV at atmospheric pressure. These values are much lower than expected. Is there an equation I should be using to convert this voltage to pressure? Any tips would appreciated, very new to working with labview and interfacing with sensors so go easy on me. Thanks!
(1,152 Views)
No need for a response I have realized my mistake. Sensor reads PSIA not PSIG
(1,144 Views)
