Interaction between two machines (systems) and creating one output data file
RandelPrandel,
I may be over-simplifying this, but since you are able to read data in from one LabVIEW program, are you able to read the information in inside of one while loop and use the Merge Signals function? This would be the easiest way to do this... However, like I said, I may be oversimplifying your application.
Best,
Jason M.
Message 11 of 12
(234 Views)
Jason,
Yes. I shall try this and see if this gives me the desired results.
I am certainly hoping this oversimplifies my application.
On a side note,  which is more effecient, build array or merge signals?
RP.
Message 12 of 12
(220 Views)
