09-25-2006 04:28 PM
09-25-2006 06:02 PM
Hi m-s,
The numerical integration.vi gets an array of doubles as a input, why don't you try to use the Array subset.vi to only integrate the part of the signal you are interested in?
Tania Lozoya
09-25-2006 08:29 PM
10-03-2006 06:02 PM
That a cool question!
This has to do with the sample rate, when you adquire the signal, you get set of samples, that hava a sample rate, and when you do an FFT on those samples, every sample corresponds to frecuency bin (kinda of frecuency samples). Example:
If you get 100 samples at 1kHz, you will get a 100 windows, this is 100 samples to represent 1kHz, however, only the half of the spectrum is valid, because of the Nyquist teorem, so this mean that from 0 to 49, you have a correct representation, from 50 to 99 you have a reflection of the spectrum. So in the first 50 "frequency samples" you have 0-500Hz
Tania Lozoya
10-06-2006 09:34 AM
