Instrument I/O Assistant not seeing my NI hardware
I have an NI 9178 cRIO chassis with 5 modules in it. Windows 7 Device Mgr sees it just fine ("this device is working"). MAX sees it just fine and the test panels there read data just fine.
But when I open up the Instrument IO Assistant and try to select an instrument nothing shows up (the list is blank). If I hit "Refresh", it remains blank.
Everything seems up to date. Using LV 2017, VISA 17.0, DAQmx MAX Configuration 17.0, DAQ Device Driver 17.0, not using GPIB/NI-488.
Any ideas?
(2,273 Views)
Accepted by topic author paul_bridges
Instrument I/O Assistant isn't meant for talking to cRIO devices.  It is for "instruments", basically 3rd party devices that have a communication protocol that is serial, or possibly USB, or GPIB.
You need to create a cRIO project and had a cRIO chassis to that project.  Look in the Example Finder for examples.
(2,253 Views)
It must have been late. 🙂
Clear that is the case and I had simply confused it with the DAQ Assistant.
That leads to another question... how do I delete this dumb question from the forum?Smiley Wink
(2,217 Views)
You can't.  But that's okay.  There is a chance someone else will have the same question and when they search for the answer, they'll find this thread and get the answer.
(2,213 Views)
