12-09-2014 08:57 PM
I have been having problems getting a code to work. So, I purchased LabVIEW for Everyone (a book) to see if I could figure out how to get the code to run right. (here is a link to that thread )
I just redownloaded and installed NI-Visa. The book says to use Instrument I/O Assistant to configure a device (PmodsGPS in my case). When I insert the assistant, I get the a gray blank screen. (see below) what does this mean? Why do I not see any options to configure?
12-09-2014 10:00 PM
12-10-2014 08:23 AM
Thanks Dennis.
I believe the book recomends it to avoid having to use the write functions and PMTK code. It basically says to use it to make life simpler. This is a beginners book and it really doesn't get into Visa functions very much. I was hoping it would dive a little futher into them.
I still don't know why you had me close one string and then open another config file only have insert another write function. I know I'm lost, but I was hoping this might shed some light on the whole situation...
