Installing and running gRPC Template creation Utility
SW:
LabVIEW 2022 64bit
grpc-labview tool
Issue:
I had installed the LabVIEW gRPC Library.vipm, LabVIEW gRPC Servicer.vipm and NI gRPC Types.vipm from the VIPM.
According with the tutorials and videos,
in order to create a server-client code, the easier way is to run the gRPC Template creation Utility ( LabVIEW Server-Client Code Generator.) However, the packages installed does not include the  LabVIEW Server-Client Code Generator.
Since NI does not support this package, I wrote an issue post on the git grpc-labview page: Missing labview_grpc_generator.dll in Load ProtoFile.vi · Issue #375 · ni/grpc-labview
Does someone uses this package and have an idea why the packages does not install the tool? Why it doesnt work?
Thank you
Dalia
Message 1 of 1
(725 Views)
