05-04-2020 12:44 PM
Hi everybody. I do not find the System Settings Tab which is referred to here:
http://www.ni.com/pdf/manuals/374714d.html
Is this a Settings tab in NiMax or in Labview or somewhere in the settings of LinuxRT on the RT-Target?
Thanks in advance.
Solved! Go to Solution.
05-05-2020 02:15 AM
It mentions:
Use the LabVIEW Real-Time Software Wizard in NI Measurement & Automation Explorer (NI MAX) to install the Language Support for Japanese or Language Support for Simplified Chinese software component on the RT target. Refer to the Measurement & Automation Explorer Help for information about the LabVIEW Real-Time Software Wizard.
So
+ in NI Measurement & Automation Explorer (NI MAX)
+ Use the LabVIEW Real-Time Software Wizard
+ to install the Language Support for Japanese or Language Support for Simplified Chinese software component on the RT target
+ Refer to the Measurement & Automation Explorer Help for information about the LabVIEW Real-Time Software Wizard.
05-07-2020 10:17 AM
Hi. This is not my problem. I have done this and it is explained in the manuals. In the ni-rt.ini on the RT-Target it shows thaa the chines and jaoanes codepages are supported, but I cannot change the locale in Ni-Max because it is not selectable.
05-07-2020 10:47 AM
05-12-2020 01:59 AM
I found the reason for the languages setting being deactivated. If the Embedded UI is selected, only englisch is possible.
Nevertheless my intention was to use Japanese with an embedded UI, so the question is answered, but it does not solve my issue with multibyte characters in an embedded UI on a RT-Target.
