06-30-2008 10:59 AM
06-30-2008 11:36 AM
06-30-2008 05:32 PM
I have Labview 6.0 through 8.5 installed on this laptop, and all seem to work ok. I have projects at customer sites that were developed over time in all of the versions. One precaution I did take was during the installation of each version of Labview, I installed them in separate sub-directories of the National Instruments sub-directory. This seemed to keep all the "extras" isolated from each other, and I didn't get any file deletion/overwrites. One other item, each version was installed in lowest to highest order, that is, 6.0, 6.1,7.0,, etc.
Hope this helps
Dave
07-01-2008 06:31 AM
07-01-2008
05:19 PM
- last edited on
08-17-2026
01:34 PM
by
Content Cleaner
Hi Paul,
As you have discovered, there is no NI-DAQmx that supports both LabVIEW 7.0 and 8.5. For your reference, here is the NI-DAQ & LabVIEW Version Compatibility for windows. The farthest back support goes while still supporting 8.5 is 7.1 (so close!
). Also, you cannot have two different versions of NI-DAQmx installed on the same computer (this would cause conflicts). This explains why the VIs seem to "disappear" from your 7.0; because 7.0 is not supported by NI-DAQmx 8.7.1.
If you were to have LabVIEW 7.1 and 8.5, you would be OK. You can also use Traditional DAQ in both 7.0 and 8.5. However, with your current LabVIEW versions you will not be able to use DAQmx in both.
You did mention that you were able to get some of the newer version DAQmx VIs to work in LabVIEW 7.0. I can tell you that while this may in fact work, we do not support it. This means that development/testing has not been done to ensure compatibility. There is no way to know what may or may not work, and what kind of consistency you will get. If your applications seem to work fine, then great, but consider this a "use at your own risk" clause!
Otherwise, it seems you have made all of the necessary considerations for toolkits, add-ons, etc..
I am sorry if this response isn't very good news for your situation, but I hope this information is useful and gives you some idea of what is going on and what you can do about it!
