09-08-2009 02:30 AM
Hello LabView, I recently did a fresh install of Mac OSX 10.6 Snow Leopard
Since then i'm unable to install the LEGO Mindstorms NXT-G 1.1 software (by LabView)
It appears that the same is true for the latest version of NXT-G 2.0
In both cases, a dialog box state that installation was successfull yet the application folder only has an Engine folder and couple other files but no App ICON 😞
Any idea if a 10.6 patch is underway to install either NXT-G sofware on my mac?
09-09-2009 09:21 AM
Hello bazmati,
As you already pointed out, the NXT 2.90 module for LabVIEW is not supported on any non-Windows OS. Unfortunately, there is no release of a new version with support for Mac OSX at this time. I apologize for the inconvenience. I would encourage you, however, to make a suggestion at our Product Suggestion Center, so that your voice is heard as future releases are considered.
09-13-2009 09:58 PM
I too am having the same problem installing NXT 1.1 software on my Mac OS 10.6.
I do not understand how Lego can advertise Mindstorms as working on both Windows and Mac if there will be no Mac software for the current Mac OS. False advertising is a serious issue. IF NI isn't writing an update, is someone else?
09-13-2009 10:02 PM
Hello again, i'm refering to the LEGO Mindstorms software and i was wondering when it would become compatible with the new Mac OS 10.6
In the LabVIEW Toolkit pdf it is said
Note: You must use LabVIEW 7.1 to create MINDSTORMS blocks, because the MINDSTORMS software is based on LabVIEW 7.1
so my question is, does LabVIEW 7.1 work on Mac Snow Leopard ?
09-13-2009 10:09 PM
There's some confusion here between NXT-G and the LabVIEW NXT Toolkit 2.0.
NXT-G (1.1 and 2.0) does work on Macintosh but will fail to install on Snow Leopard due to a change Apple made to the installer framework. Details on how to work-around this will be forthcoming.
09-13-2009 11:17 PM
09-14-2009 10:46 AM
Joel,
Thank you for the good news and the explanation. I trust the "work around" will be coming soon (an ETA would be great). The fall Lego League has just begun, and many teams will be setting up the Mindstorms software so the kids can start programming their robots.
We definitely need this sooner rather than later.
09-14-2009 11:16 AM - edited 09-14-2009 11:17 AM
09-14-2009 02:59 PM
Correction!
LabVIEW Toolkit for MINDSTORMS NXT 1.0 and 1.0.1 patch
09-14-2009 04:27 PM
BLAQmx wrote:To install LEGO MINDSTORMS NXT 1.1 on Mac OS 10.6 (Snow Leopard)
- Copy all files from the MINDSTORMS CD to a folder on your desktop.
- Open that folder and look under "Parts".
- Locate MindstormsUnivEdu.pkg or MindstormsUnivRet.pkg.
- Right-click (control-click) and choose "Show Package Contents".
- Navigate into the Contents » Resources directory and delete the "preflight" file.
- Close this package and run the meta-package (LEGOMindstormsEngRet.mpkg) from the desktop to install MINDSTORMS NXT.
To install LEGO MINDSTORMS NXT 2.0 on Mac OS 10.6 (Snow Leopard)
- Navigate into the Contents/Resources directory and delete the "preflight" file.
- Close this package and run the meta-package from the desktop to install MINDSTORMS NXT
Please let us know if these address all of your questions.Cheers,MarkLabVIEW R&DMessage Edited by BLAQmx on 09-14-2009 11:17 AM
Thanks Mark... i was not expecting a solution that easy and so soon -- i hereby confirm that i was able to install and use NXT-G 1.1 For LEGO Mindstorms on a fresh install of MAC OS X 10.6 aka Snow Leopard using the above procedure.
THANKS i will now go update my blog with the good news
