Installer build spec: Additional Installers
Recently, had to upgrade to 2025Q1 (the IT folks found a vulnerability).  Is there an easier way of going about finding out why "NI System Web Server 2024 Q3" is still on the list and not replaced by 2025Q1?
2024 isn't there anymore, and I doubt I'll be able to get it back.
The application contains about 19 other projects and compile lvlibp's that the main application uses.
My first thought was to make sure all my projects open with 2025 and changed it to reflect so in each project settings.
To confirm I didn't miss anything, I wrote a quick and dirty VI that returns the open with version.  Looks like all the projects open in 2025.
So, my current guess is some dependency is still setup for 2024..
I guess I'm asking, is there an easy way that I'm missing to figure out why the 2024 web server is a requirement (other than a lot of hunting and pecking), with the goal of not needing it for the installer?
Message 1 of 1
(320 Views)
