Installation NI CompactRIO-9030
I am following the example in compactrio
http://www.ni.com/tutorial/11198/en/
But I have error in some parts, Please check the attached file.
regards,
Message 21 of 22
(599 Views)
Hi Asgar,
what's the reason for your decision to wire the references to a BuildArray and then trying to send those references using a FIFO, which has been configured to transfer integer data?
In the AppNote you linked to they clearly show how to use the data output of the FPGA IO nodes: do you understand what you are doing there? Do you even think about what you are doing there?
Message 22 of 22
(590 Views)
