Inserting a project within a project (.llb)
I have a question concerning projects (.llb)
I have a driver VI supplied by the vendor which can be accessed through their project format (.llb). (also supplied be the vendor)
(With of course a number of dependent VI's)
Is it possible to insert the entire project in to a another project? ("my" main project ).
Sounds like this would enable me to call on any of the VI's from the vendor's overall project.?
(1,458 Views)
An llb is not a project file.  It is a weird zip-like file proprietary to NI.  And, yes, you can just put the llb into a LabVIEW project (lvproj file).  You can drag the file from Windows Explorer into the project window or add a file via right-click menus.
(1,444 Views)
Hi Chris,
to add to crossrulz' comment:
I recommend to put the content of that LLB into a subfolder of oyur project. Use the LLB Manager in LabVIEW's Tools menu to extract the content of the LLB into a separate folder…
(NI did the same for many of its older LLBs: you can find several folders inside vi.lib of VIs formerly provided as LLBs!)
(1,437 Views)
Both posts were very helpful..
Once I realized my mistake is far as.LLB versus a LabVIEW project..
Then it's all starting to become clear..
Thank you
(1,419 Views)
